HELP - FZ1 Clear Alternatives - wiring issues!
silentcropduster
GEN II FZ1
I got it used from a friend, didnt cost me a thing.
When trying to install, it has a plug for the brake light and the running light. However for the turn signals it just has 1 yellow wire coming out of each side. Doesnt appear to be a ground? I'm no wiring expert but I thought there should be 2 wires coming from each side for the turn signals? (positive and ground)
I looked on here and searched google, cant even find a picture of example of the wiring diagram.
Any assistance is high apprecieated!
The plug for the brake light does appear 2 have a ground. But when I unplug the turn signals they are also grounded, I can try to just hook up the positive wire for each side of the turn signals but I can't tell which wire coming from the oem harness is the ground or the positive.
double thumbin' it!
I have the clear alternatives light too. It is indeed grounded through the brake/running light plug. just cap off the grounds for the signal wires that you won't be using and it will work fine! I just helped a friend hook up a integrated light on an fz09 and his was the same way
