andrewclaycomb
I'm doing mine a little different than most people I think. I took the ride home from the dealership pretty easy. The total trip is about 15 miles, but I decided to take surface roads across town instead of highways. This was so I could get used to the bike's clutch and shifting points. I made a conscious effort not to stay in a single gear too long. I also engine braked every chance I got which isn't abnormal for my riding style anyway. About halfway home I saw a friend so pulled over and let the bike cool completely while I talked to him for about an hour. I then rode the rest of the distance home conservatively this time spending a little more time in each gear, but still not sitting at a steady cruise.
Each time I ride I let the bike warm up past "low" and then easily ride through my neighborhood until I feel like it's warm enough.
Every ride I've been giving the bike more and more throttle. At first I was worried about my tires not being scrubbed in but now I've almost got the whole back tire scrubbed and almost as much of the front as the back.
I'm sitting at about 85 miles now and what I'm going to start doing is on the highway do smooth sweeping throttle rolls in 2nd and third gear. After maybe 4 or 5 of these sweeping rolls I'll cool the engine off completely and then do it again. I'll probably do 5 or 6 of these cycles before I change my oil for the first time. I'm guessing I'll be at about 100 miles by then. I'm still not holding steady at an RPM above 6k, just letting the RPMS sweep, I'm also not getting above 10k at all yet.
After the first oil change I'll take the bike up to redline a few times and pretty much ride normally for another 250-300 miles before I change the oil. I'm still not going to hold a steady cruise but try to vary my RPMs.
I will then change the oil again at 600 miles and do eveything the manual calls for.
After that I'm basically going to call the bike broken in. I'll still try not to stay cruising at a single RPM for too long but I'm also not going to act like I'm still worrying about break in stuff. After 1000 miles I will be ready for long distance stuff while maintaining a single rpm. I will also change the oil then.
After that everything by the book.
I really haven't read about a method like this on the web but a lot of the local bike guys have been breaking in their built 200+ hp busa engines this way for about 10 years now, so it seems to be reliable.
It's sort of in between the hard "break it in in 20 miles" method you read about a lot and the owners manual way.
