Hyperpro fork spring settings?
Mattsplat
I fitted some of these springs last weekend and Im struggling to find a decent setting for them.
3 rings showing - a bit too hard
3.5 rings showing - starting to feel like a pogo stick
4 rings showing (as advised by hyperpro) - a pogo stick!
Everything else is as Hyperpro recommends but is there anyone else with these springs that has found a setting that they are happy with.
I weigh 85kg (190lbs) and drive sporty.
Thanking you in advance :)
Have you checked the sag? That is what the preload adjustment is for. You may need more rebound to smooth it out. I found the stock valving to be too weak to make enough difference. If you have stiffer springs it will be worse. I went with Traxxion AK-20's but their revalve of the stock cartridges is also excellent for about half the price of the AK's.
The sag was the first thing I set.
Set the rider sag at 35mm, maybe I should go to 30mm...
I also have progressive springs, not harder ones.
