NJFZ1
Well its back and better than ever..Thanks for the help.
Glad to hear that the bike is up and running again. Too bad you couldn't get a newer ECU, but that's the way the warranty works I suppose...
How does an ECU go bad?
Hope your up and running soon!
Probably the stator. Very common, my son brought an fz1 it's lasted 3 weeks Probably need new engine as the magnets have gone all over the engine fmlStart with unplugging the power commander if that fixes the problem try cleaning the connections and plug it back in.
Check that all connections are clean and tight at the battery
Make sure battery is in good condition
Check under tank for kinked fuel line ( many have had this problem )
do a search on the fuel line
Your modification list did not include a FCE from Ivans performance.
If you do have an FCE try removing it also.
Did the problem start after a fill up ?? Bad fuel ?
Have any codes ? did you check codes ?
13 years late to the party !Probably the stator. Very common, my son brought an fz1 it's lasted 3 weeks Probably need new engine as the magnets have gone all over the engine fml
Due diligence will take care of the stator issue. If it doesnt then karma does. Same goes for the white connector.On page 1 it clearly states a replacement ECU sorted the issue?
Good reminder for the ones in the back though; REPLACE YOUR STATORS FOLKS
White connector will only leave you stranded, not damage the engine!Due diligence will take care of the stator issue. If it doesnt then karma does. Same goes for the white connector.
13 year old thread is 13 years old.
White connector is a gen1 issue. 2nd gen main issues are stator and for 06-08 frame cracks.@bunk I've only owned the bike a few weeks and done the stator, what's this about a white connector?
One less thing, I'm on an 07. I checked the frame weld beneath the fuel tank when I bought the bike, all thanks to this forum basically. So far, so good.White connector is a gen1 issue. 2nd gen main issues are stator and for 06-08 frame cracks.
Far better than gsxr1000's of the era where the entire headstock weld fails !One less thing, I'm on an 07. I checked the frame weld beneath the fuel tank when I bought the bike, all thanks to this forum basically. So far, so good.
