WMU_BRONCO
It suggests you can remove the air filter without disconnecting the fuel lines.
On page 6-17 (2005 Manual) it says:
1. Remove seat.
2. Remove fuel tank bolts (points to both front and rear).
3. Lift fuel tank to position it away from the air filter case. (Do not disconnect the fuel hoses!)
Then it goes on to removing side panels, rubber cover, air filter case, and air filter.
IS THAT POSSIBLE?
If so, then how do you position the tank away from the air filter case enough to gain access without disconnecting the fuel hoses?
1. Remove seat.
IS THAT POSSIBLE?
