Looking for circuit diagram for indicator
Fastas
Hi can anyone help I am looking for a circuit diagram that shows the indicator circuits for a FZ1N.
I am trying to install a StopIt! indicator reminder on an FZ1N.
The StopIt! has three wires.
The black wire normally goes to the -ve (ground/chassis) wire on the indicator relay.
The black/red wire normally goes to the intermittent positive wire that
leaves the indicator relay and goes to the positive side of the indicator lights.
The third wire goes to the positive side of the brake light circuit. When the brakes are applied the positive feed into this wire mutes the StopIT!
However there are only two wires on the indicator relay and when you apply the brakes the StopIT! does not mute.
If I had a diagram I am sure I could sort this out in a couple of minutes.
Can anyone point to one on line?
If you have to, why don't you just run a chasis ground to the ground wire, then pick up a turn signal "hot side" then pick up the stop light lead from the brake light. It's not hard to figure out which lead is brake and which is running. You won't have to get into the cluster on the handlebars. I'm surprised the company you got the alert from didn't have model specific instructions. This should work.
