Prongomatic
Hello everyone
It's been a while since I've posted anything so I hope everyone is well.
BIKE: GEN-1, 15K miles, R1 Fork conversion,AIS removed, Ivanized Carbs, Yosh pipe, new brakes & fluid,new steering bearings,Carb coolant bypass,fresh oil & plugs,clean and oiled K&N filter, EXUP valve cleaned and lubed,SS brake lines,12v GPS charger, Hallo's installed, 530 chain and sprockets..
INFO: I'm doing all of my winter maintenance on my Gen-1. I noticed that the clutch is starting to creep when in neutral and it's getting harder to pop it into neutral when it's at idle. I have a new cable and it's fully adjusted.
I pulled my motor today. I need to change hoses, cracked intakes, and do something with the clutch. I have some time on my hands and figured I need a project.
QUESTIONS: 1)Until I open the clutch and trouble shoot, best case scenario, will heaver springs stop the clutch from creeping?
2)With 15k should I go ahead and check the valves? The bike is strong, and does not blow smoke and the motor is pulled.
3)Minus the info above, does anyone have any suggestions on any other vital maintenance procedures or fun projects that I should spearhead since the motor is pulled?
Thanks
Thanks
