3B43
Well, I did my first track day, at Thunder Hill, and to say I had FUN is an massive understatement! My FZ is stock, other then the Ohlin, Russell Day Long seat, and I replaced the stock pegs w/a set of thinner ones, for more ground clearance. The seat caused a problem with trying to 'lean off' the bike! Dave Moss set up my suspension and told me, 'your gonna have ground clearance problems with this bike' . . . which I did. I ended up dragging the hell out of the exhaust can, and had Moss set up my suspension stiffer and stiffer, in an attempt to get slightly more clearance. I dragged the can really hard, to the point that I had to take it easy, as I didn't want to unload the rear end and . . . . as far as the new pegs, I have to replace them. I ground about 20% of them off . . . at least the left one! I ended up turning lap times in the 2:12 range, which the fast guys said wasn't too bad, for a first timer (and comments from you guys that have run Thunder Hill?). I know I can go much faster, if I just hit my braking points correctly on EVERY TURN on a lap. The 2:12's I was running was with making 1 or 2 'good' turns and screwing the other turns up!
Will I go back? OF COURSE, but . . . it probably won't be w/my FZ. My FZ is set up almost perfectly for sport touring and I don't want to screw that up (I've done 6000 miles of touring since Laguna Seca!). So, I'm looking for a 'track bike' . . . . maybe an older Gixxer 750 or R1.
