whittlebeast
I have recently brought home a new PC5 with both the wideband and digital display options.
I have never been a big fan with tuning an EFI bike with a TPS based tuning systems. In the Yamaha liter bike world, that has been only the only game in town until lately when a couple of companies figured out how to hack the ECU directly. You are still stuck trusting them to know your bike.
What I have done is added to the system a MAP device that is totally self contained with the exception of 12 volts and a ground. What this device does is feed a 0 to 1.66 volt signal into one of the ports on the PC5 that is essentially the percent load (or percent power) that the motor is putting out. This is exactly the same thing that the underlying stock ECU is using to develop their fuel curves. This is all called Speed-Density fueling. I am just doing the fuel adjustment based on the same gauge of load.
PLX Devices Inc - USA
Now there are some new and amazing features in the MegaVogViewer software I have always used to look a data. The newest version is MegaLogViewer HD that was originally designed to look at Harley tuning software. It happens to be perfect for looking at the data logs coming off the PC5 data logger. The newest feature is the ability to do 3d graphing where the third dimension is color based. The software is free right now and will be fully functional till late December.
see MegaLogViewer HD
Here is a screen shot off my Stage 1 tune that I have been running for a couple of years without issue.
http://www.ncs-stl.com/pc5wb/PC5WB_AfrScatterBefore.jpg
On the left is what tuners have been trying to deal with for years. Tuning based on TPS and RPM. Keep in mind that many of these bikes still have secondary throttles that are really controlling what the EFI is controlling.
In the right is my new way of looking at things. It is all based on MAP and RPM. Look how easy it is to pick up the pattern where things go lean.
Now look at my new map that I have about 6 rides of testing in. It is not done but more of a work in process.
http://www.ncs-stl.com/pc5wb/PC5WB_AfrScatterCompare.jpg
Same view and the same scale. The lean spots at high load are gone.
Last is a screen shot of just how linear the throttle has gotten. The torque is essentially the pull on the chain. It is measured as RpmPerSec as the harder the motor pulls on the chain, the harder the bike accelerates.
http://www.ncs-stl.com/pc5wb/PC5WB_StreetAccelCompare.jpg
Way cool stuff and you don't have to have blind faith in some guy that charges $125 per hour and you don't need a $25,000 dyno.
Have fun tuning
Beast
![Pc5DigitalDisplay.jpg](/proxy.php?image=http%3A%2F%2Fwww.ncs-stl.com%2Fpc5wb%2FPc5DigitalDisplay.jpg&hash=402d738f0c991975836bb5c40f44e042)
Have fun tuning
Beast
