FSTZ1
I thought I would share this information that was sent out from the company I work for that has to do with posting pictures on the web, since a lot of that goes on via this forum.
" . . . inform you of a security risk that you or your friends and family members may be exposed to when posting or forwarding photographs taken with your smartphone. You may be inadvertently including sensitive information in these photographs because of "geotagging" features automatically enabled on your smartphone.
Geotagging is a feature on your smartphone that uses GPS to determine your location. This commonly used feature allows you to use mapping and location service applications - such as finding the nearest gas/petrol station or restaurant. Geotagging is often on by default and therefore when you take a photograph it stores information about where the picture was taken as part of the photo file using the GPS system built into your phone. Anyone using easily available software can extract this embedded location data to determine where the individual in the photo lives, works or goes to school.
When you post photos on the internet, many sites, such as Facebook, actually strip out this information so that even if you have the feature switched on, the information will not be available. Unfortunately, some websites do not strip out the information. Flickr, for example, a site designed for sharing photos, preserves the data and allows those with a Flickr Pro account to access it. If you send geotagged pictures via email, that information is also available to view by any individual using a photo viewer on their computer or smartphone.
If you wish to disable the geotagging feature for photos to protect your privacy, please follow the instructions below. By disabling geotracking for photos only, you can still take advantage of the other applications that use GPS:
Blackberry:
1. On the Home screen, click the Camera icon.
2 .Press the Menu key.
3. Click Options.
4. Change the Geotagging field to Disabled.
5. Press the Menu key.
6. Click Save.
iPhone:
1. Tap Settings
2. Tap General
3. Tap Location Services
4. Slide the camera toggle to OFF
5. Back out of the menu by tapping General and then Settings
6. Press the Home state button
If you are using a device other than a BlackBerry or iPhone, please contact your mobile service provider or the manufacturer of the device to learn how to disable the geotagging feature."
Blackberry:
3. Click Options.
6. Click Save.
iPhone:
1. Tap Settings
2. Tap General
