Hellgate
Wizard
If you have converted to the R1 front end this could be a practical guide. Overall it is a very simple process.
1) Remove MC from the bike. Be careful not to spill brake fluid on the bike's paint.
2) Remove the brake lever and plunger pin.
3) Remove rubber boot.
4) Remover circlip.
5) Remove plunger, spring, and the thing inside of the spring.
6) Carefully clean, use alcohol (IPA, as Scotch is too expensive).
7) Reassemble, reinstall on bike, bleed brakes; two full reservoirs worth is a good rule of thumb.
8) Clean up any spill brake fluid.
NOTE: I bought the R1/R6 MC rebuild kit off of Ebay, DON"T! I have no idea what kit this is for but it isn't the R1/R6.
If you need a kit buy from a Yamaha dealer.
4) Remover circlip.
