Matt R
Hello! I picked up a used 2007 FZ-1 last Thursday. I have put about 200 miles on it since then. Last night I took my daughter for a spin and on the way home it started sputtering and would occasionally die when I pulled in the clutch to stop. I can hit the start button and it fires right up. I wanted to check the side stand switch and see if it is the culprit. I put the bike in diagnostic mode and when I get to D20, it says "on", with the side stand down or up. Does that mean that the switch is probably bad and should be replaced or is there a better way to diagnose the switch?
