Rotor tint
3B43
Prior to my track day, I put a new set of EBC 'HH' pads in. Obviously, I used the brakes 'HARD' at Thunder Hill and the rotors have a slight brown/heat tinge to them. I'm assuming there slightly 'glazed' . . . is there a way of removing the glaze off the rotors?
If they are not warped a light sanding should break the glaze. Just don't use anything too rough (220 grit should do it).
