reignman
okay something really weird is up with my sisters bike. its a 1990 ninja 250. did some work over the winter (repainted, replaced the brake pads, clutch plates and adjusted the valves). so during the valve adjustment, i noticed the rocker arm on one of the intake valves was broken. replaced that and go to start it and it wont. turns over and im getting spark but no start. clean the carbs for the h*ll of it and get new spark plugs. now it starts but the right cylinder makes an awful, repetitive clunk noise (every time that cylinder would be firing). the right cylinder and header aren't even getting warm. so i pull the plug to make sure its sparking (forgetting to pull the wire on the other cylinder), and it starts up better than it did with both plugs in. WTF is going on lol:wtf::banghead:
