spark plugs
Do you have a way to cross-reference their plugs to see if Halo even makes a size for the FZ?
BroHay
Pretty sure the stock plug on the Gen II's is the CR9E plug from NGK.... if I were to put ANYTHING else in, it would be the NGK CR9EIX which is the Iridium plug.
Don't buy into the hype with odd spark plug designs... there's a reason 99% of plugs use the same design. That's what works. It's not like one company figured out something that all of the other larger spark plug companies couldn't figure out... companies like NGK have been around for a long time, and are the OEM choice of many manufacturers. There's a reason for this.
If anything out there was substantially better everyone would be runing it and all the others would become obsolete. I suppose they cost twice as much or more than the stock plugs too. I highly doubt you could ever measure a gas savings or performance gain on any of the so-called performance plugs.
