CaptainAwesome
2007 FZ1
Mivv exhaust
Powercommandor 3
KN air filter with airbox mod
AIS looked normal
unsure if have FCE yet, mods done by PO.
Issue started two Saturdays back. About a half hour into my ride the bike starts jerking after taking off from a light. Stalls out.
Tried starting it, it would catch but die off.
Code 22.
Managed to get it to run, got it back to the hotel I'm staying at (in one for work currently). No issues on the return.
Replace intake air sensor with an OEM one. Wires looked good.
Bike ran fine for a 3 hour ride. As well as commuting again.
This morning I get the same issue on the way to work, about 3 minutes in. Get it started enough to make it up a hill, dies again on the way back down.
Trouble putting it into neutral on the big hill I was coasting down, kept skipping it. First Time that's happened, might just be a separate issue like a loose clutch cable. First I've noticed it.
Mods from the PO: Power commander, aftermarket muffler, KN air filter, air horn wired separate. Unsure if he installed any of the older methods to fix some of the issues like the fuel cut eliminator.
Haven't checked the code yet, too busy getting to work on time this morning.
Ideas?
Mivv exhaust
Powercommandor 3
AIS looked normal
Code 22.
Ideas?
