- Thread starter
- #21
Klurejr
Wizard
UPDATE!
I finally had time to tear everything apart and find the leak.
I pulled the Front Sproket off and notice oil ABOVE where the drive shaft exits the motor, so I cleaned it up and ran the bike for a few min and after some higher rev blips of the throttle Oil started to come out of that cover where the Shifter Spline enters the motor. This was a big relief because now I knew it was probably just a cheap gasket:
Took it off and yep, that was the problem. Here you can see the gasket is falling apart in a bad way:
The part Number in case anyone ever needs it is:
5jj-15463-01-00
Cost more in Shipping than to purchase.
5jj-15463-01-00
