firefly
Superbike 7/8" Handlebar, Diameter: 7/8”, Width: 29.2”, Rise: 3.04”. Pullback: 3”, Center width: 4”
Bought it from ebay, $33.00 shipped, this handle bar is ~ two inch wider than stock.
I filled the bar with fine dry sand & plugged it 1.5 inch deep from both sides using plastic plugs that came with the bar to accommodate for a pair of universal bar ends, this reduces vibration at least 30%.
Since the superbike bar has no holes the protrusions in the switch assemblies have to be cut off, they prevent switch assembly rotation but without them the switches don't rotate easily anyway, or you can dril 2 holes in the stock location in the new bar to avoid cutting off the protrusions in the switch assemblies.
The result is a significantly more comfortable wrist position making me grip less tight with no forearm pumping (muscle strain), the elbows are also positioned in a more relaxed & natural position overall more control over the bike, more precision turning/ leaning & a more upright sitting position.
Hope the information is useful. will post more photos in daytime of the bar on the bike.
