3B43
Is there ANY issue w/mounting the SW-Motech hardware, for the Givi V35's when an Ohlin is on the bike, due to the dampner/preload adjusters being mounted on the side? And will a Yoshi clear the V35 bags?
Thanks!
Thanks!
It 'appears' that the front mount for the bags goes to the rear bolt on the rear peg bracket . . . . which is where the adjustments for the Ohlins attach on both sides. If my assumption is correct, I guess I'd have to make a bracket for the adjustors! Hmmmm . . . .
Anyone else have Givi's & an Ohlin on there bike?
VERY helpfull . . . Thank You! You said you had the Givi mount. Is that a simple 'bolt on' piece, or is there some mods that have to be made to mount it?
I use a flat blade screwdriver, there's one in the tool kit. Pretty easy to do.That looks very tidy, but how do you reach in there to unlatch the front seat now? It looks like it's not very easy to do...
