scottyd
Wizard
Will be looking for a shop to dyno the beast when I get back
Any recommendations?
Doin bikes at Chipping Norton.
He does it for $300 for members of my website NSW RATs - The Front Page
If I recall correctly, you are a member?
Sent from my GT-I9100 using Tapatalk
Power run is only $50 if I recall correctly.
Ok, I think I'm going to go with a PCV after I get home...
I'll have to email Doin Bikes and find out how much they want for a dual map tune...
I want to use a PCV with the dual map switch.
Personally I don't see the need for 2 maps to be quite honest, when you are on the hwy your revs aren't that high anyway.
It will cost a fair bit more to make 2 maps, that I know for sure.
Maybe call Trevor from Doin and ask him what he thinks about it?
So yeah I'll stick to the one map.Only need the one map as I map the "cruising" area of the map leaner anyway. Only time you'll use that part of the map is when you're cruising so no need for two maps
