A&P Mech
I have an 03 Bee with 32k miles. I bought the bike with 500 miles on it from a local dealer. This bike was a Mechanic's Demo bike. My bee came with an ART slip-on pipe installed. When I purchased the bike I was told that the jetting on the bike was changed to work with the pipe. I have had this bike since 2003. I have never had even one issue with it. It has run perfect until I took it to a local dealership for a valve adjustment a month ago. Not the same dealership that I purchased the bike from. I had the shop check/adjust the valves, replace the chain and sprockets and flush and fill the coolant. It was still a bit cold here when I took the bike in and it still had stable in the tank from the winter storage. The bike ran awesome as always on the way to drop it off. A couple days later I received the call to come pick up my bike. It was a very cold ride home. The bike seem to run OK but a bit rougher then I remembered. The weather did not allow for any play time for about two weeks so the bike just sat in the garage. The first chance I got, I rode my bike into work. I noticed the bike started to run rougher and rougher on the way in. It felt like one of the cylinders was missing. When I got the bike home that night I started to take a look at things. I have never fouled a plug before but I thought maybe I had a bad plug. I deiced to replace the fuel filter and the plugs. I went to replace the plugs and noticed that the number 3 plug cap was never reinstalled after the valves were adjusted. It was just sitting on top of the plug. I thought well there is the problem. I replace the plugs and went to reinstall the plug cap and the number 3 cap would not snap on because the contact that grabs the plug had burned off because of the arcing. So after a long search of the local shops no one had a replacement in stock except the local motorcycle wrecking yard. I ended up picking up a used coil with two plug caps. Both caps appeared to be in good shape. I picked one and installed it in the number three position. I started the bike up and the idle had improved. I took the bike for a ride and as soon as I let out the clutch it feels like one of the cylinders is dropping out. When the RPM get to about 2K the cylinder feels like it picks back up and there is a sharp increase in power and smoothness. The missing is worse when the motor is cold. This bike has never done this before. I have always stored it with stable in the tank. I did some reading on the boards and deiced to try some sea-foam. I poured it in my tank and road the bike for a while. No change. I returned the bike to the shop and they were sure it was dirty carbs. They said they pulled all the float bowls and cleaned them. Another $200 bucks later I went to pick up the bike. The kid that pulled my bike around asked me” Is your bike cold blooded?” I said a little why? He said” It feels like it is missing” I told him that is the reason I brought it in. The service manger hears what is going on and comes out to talk to me. After a short conversation he decides to take the bike for a ride. He comes back and tells me that it runs fine once it warms up. I am a bit unhappy with that but he asks me to take it home and try it out. I ride the bike home and it runs OK.. It is still rough. I let the bike cool down for about five hours. When I start the bike up it is running rough. I take it for a test ride and the missing is worse then ever!!! I ride it back to the shop and talk to the service manager again. He agrees to look at it again. After 5 days of waiting I get the call to pick up my bike. When I get there I ask what did they find wrong with it? The service manager said he had three mechanics look at it. They adjusted the idle, adjusted the clutch and balanced the carbs. I asked how that fixed the missing problem and he told me it was never missing... WTF????? I took the bike for a test ride and it was much better. Still rougher then I remembered. Fast forward two days and about 100 miles. The bike is starting to feel like it is dropping a cylinder right off idle again. It feels like it picks back up around 2K again with a sharp increase in power and smoothness. I have no idea what is causing this and I have no faith that the dealership does either.. I want to take it back to the dealership but I feel like I would be :deadhorse: Anyone have any ideas what could be plaguing my Bee?
