Butthead
What do you guys use for a trickle chargers
I have a ctek of which chargers my other bike plus other batts etc.
I have a spare ring connector set up of which I went to fit, but found the following issues with it
note that where the ring connector, joins the wire there's that block which is about 5mm high at the highest, and what I have found is that the neg is ok as I can attach and run it back towards the rear but the pos has that red plastic cover that doesnt allow for it to go backwards and to route it forward and then back doesnt work either as there some plastic tray thing that fits over the battery and the starp over that and the ctek connector block interferes with the fit
Given that I have just bought it, I want to avoid hacking stuff to get this to fit so what trickles are availble with longish connector wires with a slim ring to wire join.
saw a battery fighter unit but cant determine the length if the wires nor if there are any protrusions
Cheers
Cheers
