- Admin
- #41
FZ1inTX
Adminstrator
Not sure, but you can always use Excel to average the 10% and 20% values into the new 15% column and imported back.
I wonder how the software fills in that column? Does it split the difference? I'll carefully examine the 15% area and weigh the values to see how this is derived. If I don't like it, I can change it or, go to the Duken Stage III map that is not smoothed.
Who here is running a Stage III setup on a PC V and what map?
Of concern... I will be installing to a modded airbox, K&N air filter, modded flies, AIS removed, gutted CAT and Two Bros slip-on.
