Powercommander V Installation FZ1-07
Redline Rider
Dec 15, 2015
22
Netherlands
Hi Guys,
I'm currently installing my new Powercommander V in preperation of the ECU Flash from Ivan.
It looks like it works well, no error codes and the bike runs fine. Note: I only idle the bike because the roads are dirty and my FZ1 doesn't like dirty roads ;).
I have just two questions left.
- The LED of the 02 Optimizer is blinking is this normal behaviour?
- How did you guys route the cable from the PCV. I route it over the left side because of the ground cable. The main cable is littlebit to long when you mount the PCV in front under the passenger seat.
Cheers!
I recieved the ECU from Ivan. i try to calibrate the tps on the pcv. The RPM and fuel adjustment is visible in the PCV software but the TPS positioning stays at 0% and gives me no voltage.
When i check the tps on the dash (with reset and select) is get 16 at idle and 91 at full throtle. Somebody any idea?
Problem solved. I contacted powercommander and they send me an older firmware version (0.1.10.6). TPS readout is now flawless.
To everyone: Don't upgrade your pcv firmware to 0.1.13!!
