Greg the Pole
good morning all, Greg here from Calgary Canada. My current stable: 2020 NINJA 1000SX. 2019 KTM 1090R. 2021 TE300/GG, 1998 CBR 900RR project that i'm just about ready to set on fire...vids on YT if interested.
I'm currently going through a friends recent 2006 FZ1 Purchase (I needed a break from the 900RR PITA project). Seems very clean, 63k km. It's salvage titled bike (broken rad pipe, scratched pumpkin turn signal..that's it) , that needs the usual...stator (AND BEARINGS!!) , tires, chain, valve adj (more on that below) and odds and end.
Started a quick vid. thread on the subject if anyone is interested. Found some tasty stuff on the rotor..the shop changed in a newer R1 rotor and still wasn't right.
Question on valve check. Yamaha states IN 0.11-.20mm, EX 0.21-.025mm. I followed the TDC setting per the book (twice). All the valves, intake and exhaust have massive gaps.. 0.30mm goes in like a hot dog down the hallway..head looks spotless, spins with no issues, valve train and bottom end are spot on, am I missing something?
Will hook up my leak down tester and see what's what.
Bike has only ran for very short periods, and likely sat for a long time.
Vid here, I don't get into the valves on this one. I will post up a shortie on the valve issue.
thanks in advance,
Greg
thanks in advance,
Greg
