Another wet week-end, work
While the snow and rain came down all weekend, I worked in my garage. I was not
enjoying the ceiling sheetrocking, so I rented a "Drywall Lift" on friday on the way home from work. It breaks down into 5 peices for easy transport (even in my vintage Tercel hatchback). By midnight on Friday the ceiling was finished!
Too easy with the lift, 10' sheets of wallboard by myself and no sore head, no broken sheets, no trouble, the lift doesn't get tired holding. Returned it on Saturday morning, job done ($35.00 at Home Depot Rentals-Well Worth It). Then I installed a second dual 8' flouresent light at 90 degrees to the one I installed previously. That should do it for lighting (it's bright in there now). Next I installed moulding around the "man door" and the attic stairs. I found a product called "safe door" at Home Depot while I was there and installed that as well. It is a metal "C" channel that slides over the edge of the door where the bolt goes through and is glued on with silicone. Most metal door have a weakness in that the edge of the door is wood and is vulnerable to kick in. The metal channel eliminated that weakness and comes with a Heavy duty strike plate that is about 10" long with holes for the door latch and dead bolt, and comes with 6" screws (long enought to go into the double studs around the opening. When I was building the garage I installed cross braces on each side of the door between the studs to prevent the opening being spread (with a jack) as some thieves will do to get past locks. This makes me feel a bit better about the security of my Toy Shop.
At the very least the thieves would have to work much harder! Safe Door Systems - Door Safe System
After all that I installed a new shop vac (wet / dry) that hangs on the wall, I got a smokin' deal on it ($50.00 off at Canadian Tire).
Then I sorted out all my tools and put them in a proper tool cabinet.
Finished off with a bit of cleaning. It is still raining and I am out of things to do. I will take some pictures today of the progress, (it will give me something to do.
