My Yoshi Headers arrived!!
The slip-on he has is a Yoshi so it should fit the header.
What does being the same brand have to do with it? His Yoshi slip on is designed to fit the stock pipe right? If this slip on also fits the Yoshi header then that would indicate that any slip on will fit the Yoshi header. Perhaps an adapter is required?
I wasn't under the impression that any slip on (designed to fit the stock pipe) will fit the Yosh header but perhaps they do. What's the deal Gcontroller?
Thanks mate but I have been a good friend of Ivan's and Pat Glenn for many years and have all their past specs but I am looking at new users and comparing them with Dale Walker Holeshot Performance Products, Inc. who I have also dealt with for many years.
All I would like is a basic opinion from the rider, I already have all the published specs.
Thanks again
Chris.
How will you mount it to the slip-on you already have?
Will the mid-pipe need to be modified much?
I was told it would mount right up. I think there are two different typs of Yoshi headers. Everything looks like it should mount right up. The supplied system looks like it's the same size as the current set up where the headers meet the slip on.
Here is a pic of the new pipe that comes with the headers. As you can see it's a bit different to work with the full Yoshi system yet still fit the slip on fine. The segment witht the rubber bumper works with the stock headers and Yoshi slip on. The other segment is going to replace it.
