Dustin
Moderator
It's about $1.45/L here in Canada which is about $5.50/US gallon. I always fill up across the border when I can to save a few bucks
What Octane fuel do you guys run in your bikes?
Being in California we do not have access to the really good stuff except for a few rare gas stations.
I put in the top Grand 91 octane for the first fill up, but can I get away with the 87 octane?
Thanks for the replies, I have put in 3 tanks now at 87 Octane, and everything seems to be running great. I may try the method of doing every 5th tank as premium grade to help keep the injectors clean, etc, etc, etc. It is not that much more expensive to do it that way.
Do your research first because the whole additive thing is deemed to be a bit of a farce perpetrated by the marketing folks at the oil companies. Sell the higher octane fuel as a 'better' fuel and rake in the profits. That's why people always say they 'spoil' their bike/car/whatever with 'the good stuff'. Brainwashed by the profit-mongers
I will never use more than the manufacturer's recommended fuel unless something has been changed that requires it
When you collapse the skirts of your pistons from detonation you can't hear you might think differently. 20 cents a gallon which equates to roughly 90 cents a tank on an fz1 is worth not having the possibility of detonation!
Regular fuel (87 here in the U.S.) is all our bikes need or want if they are tuned correctly. By that I mean they are getting the proper fueling (A/F ratio not too lean) and ignition timing correct. I'm amazed, as much as the subject has been slaughtered, that so many people tend to call higher octane fuel the "good stuff" and regular the "cheap stuff". The price may be different, but that moniker leaves people to have a displaced value to different fuel types. What we commonly call knocking is cause by excess heat in the combustion chamber NOT the compression ratio. A head that has poor design may be far more prone to detination because of heat, even at a relatively low CR than and well designed head at a far higher CR. If this weren't ture, Harleys would never has a problem (9:1 CR or so) and the FZ1 would never get beyond the end of the block. This is a simplification, but when someone thinks they are experiencing knocking, looking at what's causing the heat problem will take care of it faster than adding expensive fuel additives.
If that ever happens to me I might reconsider but based on what I know and what I've experienced, I'm happy to continue using what the manufacturer recommends.
Besides, the difference between 87 and 91 up where I live would be about $2-3 a tank. At 80 or so tanks of fuel per year, that's a lot of money! Coupled with the fact that an engine not designed to utilize a higher octane fuel, shouldn't that actually leave deposits as a result of the mixture not being fully ignited?
Your air to fuel ratio is what tells you whether or not you have a complete burn, not the octane of the fuel.
86=HP so that what I ran in the Fz
Your air to fuel ratio is what tells you whether or not you have a complete burn, not the octane of the fuel. The less refined fuel (87) has more impurities in it than the 93 and that is what leads to the deposits. My personal opinion is that the difference in the price (even if it were 2 whole dollars a tank) does not deter me from using it. I have seen firsthand what it can do and prefer not to chance it.
The Australian owners manual must be a bit different to the USA one, on page 3-16 it says - Your Yamaha engine has been designed to use regular gasoline with a research octane number of 91 or higher.If knocking[or pinging] occurs,use a gasoline of a different brand or premium unleaded fuel. So I guess its up to you what octane your happier with. On a different subject oil ,page 6-11 it says -Do not use oils with a diesel specification of Cd or oil of a higher guality than specified.[another can of worms]
Research Octane Number (RON)
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.
Anti-Knock Index (AKI)
In most countries, including Australia and all of those in Europe, the "headline" octane rating shown on the pump is the RON, but in Canada, the United States and some other countries, like Brazil, the headline number is the average of the RON and the MON, called the Anti-Knock Index (AKI, and often written on pumps as (R+M)/2). It may also sometimes be called the Pump Octane Number (PON).
