$63 Power Commander?
I would not touch it. It does not allow you to truly adjust all the settings in your fuel map like PC does. It is just some preset maps that you can cross your fingers are half way decent.
I was hoping someone has already tried on. The say it comes with 15 pre-loaded maps that cover most situations. If it already had a decent map could it be worse than the 06/07 map?
Forget I started this thread. Its a POS. Basically its a set of resistors that taps into the air temp sensor that tricks the ECM into adding fuel. Not a programmer at all.
