FazerRider
Nice video but hard to believe. Yamaha FZ1kills Honda CBR1000RR in Roll Race FullTilt - Video
why hard to believe ? I "own" blades and R1's all day on mine !!Nice video but hard to believe. Yamaha FZ1kills Honda CBR1000RR in Roll Race FullTilt - Video
I think the rider on the Repsol just sucks period because with like riders, I would find it hard to believe the FZ1 will pull away like that.
Let's see this with two riders with the same skills.
I had an 04 CBR 1000 and if the CBR in the Video is stock, and the FZ1 is down a tooth on the front sprocket like the video says then I can believe it. My CBR only put out 149 hp stock and wasn't all that strong for a 1000 in the mid range. The shorter gearing on an FZ1 with a slip on will make enough of a difference for it to pull away slightly. Keep in mind that the 06-07 CBR's were geared shorter from the factory and had more of a hit in the midrange than the 04-05 CBR's, so for those years CBR's the story would be different.
You are referring to an 08 CBR 1000, not the 04-05 CBR that was in the Video. Your CBR is very mid range strong, quite a bit stronger than the 04-05 CBR as seen in the video. A properly tuned FZ1 can pull anywhere from 140 to 150 hp, right where a stock 04-05 CBR 1000 is. If the gearing is changed on the FZ1 and not the CBR it is easy to see how the FZ1 can pull away slightly. BTW, the FZ1 in the video pulled ahead slightly, he didn't crush the CBR.
