This may only apply to Gen 1s however, when you adjust chain length do you loosen the bolt for the rear brake stay ? I've always done so because it's in the instructions but, I'm wondering what happens adversely if you don't? The axel will still move if you don't.
Does it change the rotation/orientation of the caliper on the axle, does it change the angle of the stay? Does it prevent the connection between the stay and caliper from galling?
I just put on a new DID 530 and sprockets and was adjusting it after a couple 100 miles of use. Which is how I got on the subject.
While we're talking about that bolt the lock nut on the back is always a b#%$ch to locate with a wrench.
