Dreamdemon
The idle is best a bit higher than what Yamaha recommends at least that is my experience and from other posts I see that many share this opinion. I would set idle to about 1200 at 180F engine temp. The idle can be adjusted by the screw on the left side of the engine, it is a small hand turnable screw (do not know the English name for that type). You have to adjust the idle for each map.
