Nmgator
Hello I have a fz1 2001. I blew my motor last week and was wondering if a 2001 R1 motor will fit in the place of my old fz1 motor. Thank you
Was the R1 motor fuel injected in 01'?
I don't know if it's fuel injected, I know my old fz1 motor was carbureted
Let me help you out: Let me google that for you
but the rejetted carbs and AIS is what ended up in the FZ... not the previous model R1 motor.
2000–2001
In 2000, Yamaha introduced a series of changes to improve the bike, plus minor changes to the body work to allow for better long duration ride handling. The R1 was an excellent bike to live with on short runs, but due to its quick handling was not a favorite longer run bike. Yamaha's main design goal was to sharpen the pre-existing bike and not redesign it. Even so they instituted over 150 changes in hopes of making an already light, sleek and mean motorcycle even lighter, sleeker and meaner. For example, even with the addition of the new Air Induction System, which weighs four pounds, the overall weight of the bike is down five pounds to 414 lb (188 kg)[7] dry. At 127.8 bhp (95.3 kW) at the rear wheel,[7] top-end output remains the same but changes to the engine management system are supposed to result in a smoother, broader distribution of power.The bodywork is still unmistakably R1 although a few changes were made resulting in a 3% reduction in the drag coefficient. The headlight housing has a sharper profile, the side panels are more aerodynamic and slippery and the windscreen has been reshaped for better rider protection. In fact the bodywork changed so much that bodywork from previous R1s will not fit the Y2K edition. Also updated is the seating area. The fuel tank is reshaped with a more relaxed rear angle and deeper leg recesses to provide for better rider feel. The seat extends further towards the front of the tank and the new, steeper seating position puts additional weight on the front end. All of this is aimed at improving weight bias and offering sharper cornering and more stability. Again, the resounding theme here is to sharpen what was already a very sharp package. The carburetors have been rejetted in an effort to improve throttle response—especially in the low end—all the way up to the bike's 11,750 rpm redline. The redesigned camshafts are lighter and use internal oil ways to lubricate journals that, when combined with reduced tappet clearance, provide less friction and create less engine noise. Also changed within the crankcase is the gearbox featuring a taller first gear, a hollow chrome-moly shift-shaft with an additional bearing and a completely redesigned shift linkage and foot pedal. These changes are aimed at nixing last year's transmission complaints as well as helping to transfer as seamlessly as possible the R1's prodigious power to the pavement
