ecruz
Anyone know roughly how long it will take to install Givi side & tail cases?
Anything special I need to know before starting?
Thanks
Thanks
Also the right frame mount needs to filed to clear the welds.
I have the Givi quick release racks. Yes I saw that the whole tail needs to be removed. Doesn't look like a huge job. Anything special I need to know about that? Which mount needs to me filed?
I had to do some filing on the two pieces that slide into the end of the frame. The inside of the frame tubes have a lot of extra weld inside. Not a big deal, 15 - 20 minutes or so.
Someone posted pics a while ago (maybe OLDSCHOOL?).
Good Luck,
MrHix
I really didn't have too much trouble mounting the turn signals or running the wires back to the connectors. Only thing that I had to do was extend the wires a few inches on either side the way I ran them.
Show off your latest endeavor!
Not sure when you did yours, but the turn signal mount that came with my kit are completely different than the one shown in the PDF on Givi's website. Maybe that had something to do with it. Or maybe I'm just mechanically un-inclined.
Either way, they look really nice!
Well as you can see your turn signals attach differently than mine. Givi must've made a change recently. I got mine last Fall.
