FZ1riderNY
Looks like it will work just fine. get it on the bike and lets see for sure. nice work buddy.
Thanks Mikey! I may have to try it out tomorrow after work. It's raining right now but tomorrow should be good.
K.I.S.S., just how I like it!
does it have "some" resistance to rotation? so it doesn't go into a swing
guess you'll be able to fine tune it better after a couple test runs!
can't wait to see this, def. something anyone could do with a little bit of spare time and supplies.
hey Billy this looks a great gismo....:+1:
I think that with your current design, if you get too much swing on your test run, you can drill a hole in your aluminum that the camera is mounted on, on the opposite side. tap it for 1/4-20 threads, and hang a lead weight on the bottom.
That would flip your camera up to the top side, and I think a bit of weight on it would reduce back and forth swing... you might need to put a brace across the bottom of the setup though, where the GoPro mount hooks up to your uprights, just to make sure it doesn't begin to droop with that added weight.
I think you've got a really good start, and I can't wait to see the results of your testing. You managed to keep it very simple, and if there is any problem, it'll likely be very easy to make a fix as I said above.
Bill the stick-on motorcycle tire weights might work great for that.
Awesome project!
Exactly Pete. I may pick some up at Cycle Gear this weekend if the swinging occurs.
Nice! Harbour Freight has stick on wheel weights if one of those is near and your going to need a bunch. I think it will do OK on smooth roads once you get the counter-weight figured out. Most of the roads I get to ride are very bumpy as seen in my videos.
That's right Mike. I've seen all your vids and I don't think this unit would hold up to that kind of road. I'm gonna check it out on the mountain where it's nice and smooth, at least for a first test. I'll post it tomorrow when I get back, stay tuned!!
I'm looking forward to this too. I think you won't have too much trouble with wind, the camera should be heavy enough.
No link???
