Drewbaloo
That’s great i like it. I’m 5.10 and i was planning to put gold on to match my gold wheels but debating black ultra low 758’s.
Did you have to drill holes for control mounting?Yes the renthal bars are nice I got the low rise with stock risers and pro grips
Yes, but it's not hard. Just make sure they are installed and straight so you can see how the controls should be when installed.Did you have to drill holes for control mounting?
The latter is what I do. The hole drilling way is annoying and limits handlebar and grip placement.Yes, but it's not hard. Just make sure they are installed and straight so you can see how the controls should be when installed.
Some people just cut off the plastic nub on the controls and use a little bit of tape on the bars to make it slightly wider and thus hold when you tighten it down.
