moosecapades
Why not just put the Yamaha specified 190/50 ZR17 tire on to get the rake and trail back into a safe and more importantly, stable range.Nah, I have an adjustable rear suspension link on the way (should be here ready to install on the weekend) and I generally clutchless shift anyway.
I need the adjustable suspension link to lower the rear 6mm to get the geometry for the 55 profile rear set up right. It's still too twitchy on corner entry, and I'm maxed out on the Ohlins forks.
I think Blanchy has something similar if not the same as this quick shifter, pretty sure he did a write up on it.
You're setting yourself up for a bad tank slapper.
