coolzzy
Hi all, I just got my new rear tire installed (stock size) and now have a new problem. Before I had the tire installed I had no issues other than the big flat spot running down the middle of my rear tire. Well I got the new tire on, and since it was taller from being new I had ot adjust the chain tension (loosen it up a little) to be in spec. While I had the bike in the air I figured I'd clean all the gunk off my chain as well using WD40 as i've seen reccomended everywhere.
So I got the chain all shined up and de gunked and I take it for a Spin. Immediately I notice a clicking noise coming from my front sprocket cover. I put it back on the stand and spun the rear wheel and could just notice a faint clicking once the wheel got moving fast enough. It sounds like a bearing going out, but is there a bearing behind the front sprocket? Doesn't it just bolt on? I removed the sprocket cover to make sure everything was there and the sprocket looked fine, no abnormal wear or rubbing so i'm stumped. The noise is loud enough that you can hear it riding next to me on another bike, kinda like small ball bearings. The noise is present in all gears including neutral and clutch pulled in, stops when the tire stops.
I thought maybe I had removed too much grease from the chain so I lubed it back up with white Lithium chain lube, let it sit overnight, then went out for a ride again with no change. Any idea what could be causing this? The only thing that has changed is the new rear tire (which makes a HUGE difference in corners compared to what I had been riding with) and a clean chain. I adjusted the chain slop per the manual so i've got about 3/4" play in each direction midway between the sprockets on the center stand from the tightest point in the chain. Torqued the rear axel nut down to 108ft/lbs, the noise seems to be localized at the front sprocket cover though......
