Be careful torquing the drain plug - there's diff in torque specs for a dry bolt vs a bolt that's wet with oil. I don't torque mine, just snug it up and then give it another go - what I have learned feels right. Never lost one or had one loosen.
I used mag drain plugs on all the two strokes I've owned - 350s - the R5, RDs (several) and the RZ and the RT2 Enduros. If they were new, I had plug switched before it left the shop, if used, it was the 1st thing I did when I got it home. They collected an amazing amount of metal debris. On the four strokes - I use done when I could find one. These seemed to have a lot less debris inside, but all my 4 strokes were bought used. My CBR is the 1st with an external filter.
With a filtered oil system, not sure how important these are anymore, but Zak makes a good case for using one.
