Lonney
Wizard
Buggy how long did you run your bike with your engine mods before you installed your juicebox?
I see at least 4 engines on Ebay now from $950 to $1500. Considering shop rates these days its a cheaper option unless your doing the work yourself.
( if you have major damage )
OK, got home from work and tore into it. First thing I did was start the bike up and felt the pipes to see which one wasn't firing. Cylinder #1 was cold to the touch. So I started by moving the rad back too get at #1 and unplugged the other three coils. I removed the #1 coil and spark plug and cranked the motor over to check for compression and I get a spray of fuel from the spark plug hole and it keeps pulsing out every time the piston comes to the top. I start thinking fuel injector and pull the tank and air filter up. I removed the fuel rail and all four injectors then with the injectors installed in the fuel rail and wires attached turned the key on to check for leaks. Number 1 injector immediately starts spraying fuel all the time the system is priming and the other three remain dry. I switch the #1 for the #2 injector and try it again. #1 injector position is still spraying fuel in the swapped injector. I then decide to unplug my Juicebox Pro and run straight from the ECM and the problem goes away. I've contacted the company to get warranty, it's only 3 months old. The thing that got me was this morning the oil coming from the exhaust. It was dripping from the pipe and when I rubbed my fingers through it, it feel slippery and had a dark colour like oil. Anyhow glad things turn out the way they did and thanks to everyone for your suggestions and help.
:yes::thewave:
The fuel dumping into the cylinder may have gas washed and damaged your rings, contaminated the sump and ruined the bearings or even bent a rod if the cylinder filled with fuel. I'd really have a close look at the engine before you contact Juicebox so you know just what they should be paying you for. I'd think about having a shop confirm that the juicebox is the problem ( and get it in writing )
EDIT : I'd take some video of that injector with and with out the juicebox hooked up. You may need some evidence
Hopefully everything works out well. Stick with tried and tested devices like PC3/5. This is another reason I am leery of piggyback controllers and giving too much power to tamper the fueling to the user i.e., US.
I have had my PC5 fixed out of warranty ....
I now do wonder about the reliability of these fuel controllers. Anyone else ever have a failure of their PCV or Pro?
My PCV failed within about a month of buying my bike from a dealer, they diagnosed it and replaced it under warranty for me.
My symptoms were engine missing & surging in mid rpms, cutting out at idle, poor starting, i thought i had a serious engine problem - i was shitting bricks lol
When it happened I pulled over then rode it home for maybe a maximum of 2 miles. I drained the oil tonight and didn't notice any fuel smell in the oil so I'm pretty confident that bearings, cylinders and rods are OK. The motor never hydraulic locked and actually ran smoothly without any abnormal noises, just a lot of smoke. I will check the compression after it's running to confirm I don't have a problem. A little on my history, I'm actually a Class A automotive technician and have seen this scenario occur with automotive engines without issue. Even after a compression test if found the a problem it would be a very uphill battle to get Juicebox pay for it. How would you prove that the compression problem was a result of there product? With used motors selling for $900-$1500 dollars it would be easier for me just to replace the motor. Don't get me wrong, I will be calling them in the morning with my issue.
