amevl
Wizard
The graves is my favorite for looks but way to pricey,I'll keep my MIVV.
Yes, you just need to drill the rivet - as soon as you cut the head off of it with the drill it will come out, and the Db Killer will come out easily, maybe a slight tug to loosen it.
You can run fine without remapping.. you will have a bit more popping with the Db killer removed.
As far as how loud it is, you'll be able to decide for yourself.. we like them with the DB Killers out and don't think that they are too loud.
Knew I was rubbish but bl**dy hell lol.
Stay away from those cheap B&Q drills? lol. You will need a 3-4mm bit, it should pop on out if not go to a 5mm bit and slowly drill the head of the rivit,you may need to give it a little tap with a hammer & punch. Tip, spray a bit of WD40 on the tip of the drill bit.
Lol - not wrong re drill - it is a cheapo cr*ppy one. Will try again 2moro with WD40 also.
I will succeed, no matter how long it takes (got braddle and hammer at the ready!!)
Cheers
