meinschaft
Does anyone know if the stock FZ8 muffler will fit a Gen II?
I looked into this some time ago. From what I remember the joining gasket (sealing ring) from the two bikes appeared to be the same diameter so I guessed it would slip on the the header ok ,, that said the fz8 rear mounting sits further forward than the gen2 So I reckon Its shorter so won't be a straight swop , but I'm sure with a little modification it would go on .
If I could have found one cheap enough at the time I would have had a go ...
Are the header pipes the same diameter as the FZ1 or smaller?
