Jure
I usually have to rework all of the non-oem parts that I install on bikes. Maybe I'm just picky.
I don`t know what brands are you buying, but I never have to rework anything when I buy brands like Rizoma, Puig, Pazzo, Braking, etc.. But on the other side I have to rework something almost everytime when I buy something from China.
Anyone who installs a set of levers without testing them before riding is a fool. I did have to ream my master cylinder lever pivot hole. This could have caused a problem if not corrected. Proper installation is always required on anything.
When you install levers with bad tolerances on master cylinder lever pivot hole, levers sometimes work just fine when you test them. If you do not lift the front wheel and check if the wheel spins freely, you can easily think that everything is ok. You go for a ride and then.. I always check everything. But believe it or not, some people do not. Idiots? Maybe. For me it is just not acceptable that some people are selling such dangerous parts. If you buy and pay for a lever for xx model, the lever should fit on that xx model without any modifications!
Any bar stock aluminum is stronger then simple cast parts. I bought silver levers to avoid the anodize issue. I have been using anodized parts for decades, from many different countries and they all fade over time. Protective coatings on the more expensive levers helps this. The Chinese levers are cheap because of cheap labor and currency manipulation by the Chinese government. Just my opinion.
True. If the aluminium block does not have some foreign object inside it.. It happened at least once.. CNC milled lever just snapped in half.
The Chinese levers are cheap because of cheap labor. But not just because of that. Chinese products are also cheap because crappy cheap materials are used and also because quality control is shit.
I once broke in half a 22mm chinese wrench (it suposed to be made from chrome vanadium steel, yeah sure) with my bare hand. And I am no bodybuilder!
