cjbottaro
Ok, I've had my FZ for 5 days now... been getting used to its quirks and doing a lot of reading (this forum nas been great). Here are a list of quirks and my solutions to remedy them... everyone's opinion is very welcome.
Reluctance to lean
I'm having new tires put on Monday (Dunlop Roadsmarts, very happy with them on previous bike). If that doesn't remedy the situation, I'm going to have a suspension guy take a look at it. Might do that anyways just to setup the bike specifically for my body type, weight, height, etc.
Needs a lot of gas/clutch to launch from stop
I've determined this is due to the characteristics of an I4 (vs my old v-twin) combined with extremely tall gearing. Will going to a 16/47 sprocket combination alleviate this somewhat? Also what does 520 vs 530 mean? Is that chain weight or length or something?
"snatchy" throttle
I'm not sure if I'm using the correct terminology, but if I completely let off the gas, then reengage the throttle, the power comes back on very suddenly... enough to throw my shoulders back some. I have a 2008 FZ which shouldn't have this problem as much as a 2006, but it's still possible that it does... ? Solution being an FCE or flies mod? One, the other, or both? Flies mod is definitely cheaper...
too tall (bike is, I'm too short)
I can put my heels on the ground, but not with a very wide stance. I'd rather not mess with the suspension and kickstand and all that, I'm thinking about having the seat modded by greatdaytoride.com.
hard luggage
I like the Givi V35 saddle bags. Seems the two mounting options are Givi PLX/PLXR or SW-Motech Quick Release Contour. Any opinions on which to get (they both seem to be about $250... ugh)?
clutch engagement at my finger tips
I know the manual describes how to adjust the clutch cable but, correct me if I'm wrong, that adjusts how much from when the clutch starts to engage to when it is completely engaged. What I want is the move the clutch engagement start point closer to the handle bars. For this, I need an adjustable clutch lever?
Thanks, all.
Reluctance to lean
"snatchy" throttle
hard luggage
Thanks, all.
