scottyd
Wizard
Has anyone tried the Power Commander V with Dual map & switch?
So when you change maps with the switch, do you have to do anything, like let the engine drop to idle while riding to change or turn off the engine to do it?
Sweet thanks Super G! I might after all get a PCV instead of the ECU reflash.
I was thinking about the flash also, but went with the PCV. Just not enough feedback yet on the flashing and I see one guy on the other forum has had a few issues.
Some guys have reported they love the flash but from what I can tell they all just run a slip-on. I'm more comfortable with having the ability to make adjustments with the PCV as apposed to being limited to a generic map with the flash.
So far it does not appear that different flashes are available for so many combinations of mods. Stock airbox, modded, full exhaust, slip-on, stock flies, small flies or none. Just to many variables to expect a few generic flashed maps to work well. What about the differences between a guy that lives 5,000ft above sea level compared to a guy at sea level ?
Currently I'm much more at easy with the PCV and being able to try different maps or have a custom map made.
I was thinking of having 2 maps, a power/normal tuned map and one suited for a slightly leaner fuel ratio in the rev range for cruising on the highway...
You don't need a switch to do that with the PCV since you can map your bike per gear. The way I did mine is Gear1-3 are "Sport Maps" and 4-6 are "Touring Maps" What I did with the Touring map is leaning under 40% throttle. (13.8 with Auto Tune, that work like crap by the way) and keep the same map for hard acceleration.
Ah ok thanks for that. I din't know that could be done with each gear! :tup:
The stock ECU has a nasty habit of changing the AFR targets seemingly randomly.
Beast
NEW Power Commander V - PTi
On select models a new version of PCV is now available that’s perfect for forced induction applications. This new unit, PCV-PTi, comes with a Bosch 3 bar MAP/Temp sensor as part of the PCV harness for expanded capabilities built into the control center software. res.
The PTi version of the PCV gives you the ability to modify your fuel curve based off a pressure (boost) table and/or temperature table. The pressure table gives you 3D mapping capability based on boost vs RPM, while the temperature table gives you 2D mapping capability with up to 50 points of adjustment.
This new version of the Power Commander V is perfect for turbocharged or supercharged applications looking for precision, control, and reliability.
Why do they change? shouldn't they be fixed for each load point (or throttle position)?
Any chance of it being a wiring fault?
ie. going over a bumb shorts out or looses connection on a wire??
