FZ1riderNY
Voltages to check go along the lines of what MikeGTX2002 said. I have a 2001 and have experienced the ignition switch problem and it acted like you said.
1) Connect your voltmeter negative lead to the negative battery post securely.
2) use a 12volt to 20 volt scale--if higher it will be too hard to distinguish differences.
3) Pull the headlamp fuse to extend the life of the battery while troubleshooting.
4) turn on the key and measure the battery voltage at the battery post--it should be around 12volts ;-)
5) Open the fuse panel and measure the voltage of the ignition circuit at the fuse--how much drop is there? Momentarily put the headlampo fuse in--how much drop?
6) Pull headlamp fuse again, measure voltage on ignition fuse while wiggling key--does voltage change?
If you have a bad switch, you will get a lot of voltage drop when you check the ignition fuse, especially with the headlamp on.
Please let me know what you find before going further.
I went and did the above test. Here are my results. This was before cleaning any contacts so not to taint or mask any problems. 1- With key on at battery post = 12.1 Volts, 2- Headlamp fuse out, key on, voltage at ignition fuse = 11.9 Volts, 3-Headlamp fuse in = 11.1 volts, 4- Headlamp fuse out, jiggling key = 11.9 Volts with no changes while moving key rigorously. I also turned the handlebars left and right while testing voltage at the ignition fuse and no drops or changes in voltage.
I'm really leaning towards the fuel pump having an intermittent problem. I have good spark at each plug, primary resistance on each coil = 2.8 Ohms, secondary resistance on each coil = 17,100 Ohms.
I used my electronic contact cleaner spray and sprayed the ignition switch, and also all connections behind the right side panel. I also sprayed the kickstand switch being that I was there anyway and it wouldn't hurt. The main problem is that being an intermittent issue, I can't make it happen when I want to. The bike started fine although I do notice that on full choke the bike will only rev at 1500 rpm's, when before it would rev to almost 3,000 rpm's. Once warmed up the bike is running fine. I'm still suffering from some mysterious fever so I can't take the bike out for a test ride although it may run great anyway. After thinking it was bad gas and changing it out with fresh gas, I rode the bike 3.3 miles with no problems at all. Then this past Sunday I went down to ride up to the mountain and turned the key to find out the problem was back again like magic.
Before just packing the bike up and running over to Ivan, I'm going to see if I can swap out the fuel pump and see if the bike runs okay. If the same thing happens with the other pump then I'll leave it to the professional. Winter is around the corner so I'd rather pay and have it done right and have the confidence that I won't be stuck out in the middle of nowhere again like last week. It's the worst feeling to be stranded hours on the side of the road.
Thanks for all the troubleshooting advice!
