fz1985
If u had the Velocity stacks with yosi exhaust and no power commander will it still pop. 09 fz1
Where is the AIS located
That picture is of a Gen II and this was posted in the Gen I section. I'm not sure how different that will make things, but I doubt your Gen I air box will look the same. Just sayin'...
Troy? Who posted here with a Gen I bike?
It's in the Gen I Tech section of the forum. Maybe it's in the wrong place?!?
So all the blockoff plate kits and the bitch install is pointless? You just cap off that nipple? That seems like the way to go unless I'm missing something.
I do believe the air filter shown in open air box view is installed upside down.
I just put one of these filters in my FZ8. Extremely similar if not the same box and the same BMC filter that the FZ1 calls for. The rubber seal should be down against the rim on the intake side of the box. Had to finagle a little bit to sit just right but is good now. I returned my K&N for refund after found top cover gap could not be easily dealt with (on my FZ8). Got a BMC for my FZ1 also but will wait for the stock filter to need replacing to install.
