Ssky0078
Wizard
I wouldn`t be changing the fork springs until I set the sag,and did some adjustments to suit your riding style,then ride it for a month or so,several thousand mile,use cable tie`s around the sliders to check the distance of travel,before I would decide on doing anything.
Might be cheaper to approach it that way. I just know that during my crash one of the reasons I just didn't come up and get on the break is that after my back tire slid out, is I then let up on the throttle, this caused a nose dive. It scared me and I didn't want to get on the brake to avoid further sliding and on the flip side possibly throwing myself over the front. I guess if I knew how to drift a bike then I would have been fine.
I've been watching a lot of crashes and close calls lately. Most of the close calls the bike stays seated the whole time, and the crashes there is some weight redistribution going on usually forward on the forks and the back tire goes out lowside or they get tossed high side.
In my mind stiffer springs for a couple hundred bucks is worth it if I'm more securely riding down the road. The stock spring is setup at 0.920 kg/mm and my recommended rate is 1.062 kg/mm. That is at least 2 springs stiffer than the stuck. The stock spring is for a 150lb rider, I'm 250. If you can explain to me that through manipulation of the stock suspension adjustment that it can acount for approximately 3 standard deviations from the median and I would still be safe it's worth not changing. .
