scottyd
GIpro X-type gear indicator custom install Development thread....
Ok, so as the story goes we have seen a vid on youtube on how to install the GIpro X-type gear indicator into the Gen II dash.
So here is the vid:
[ame=http://www.youtube.com/watch?v=lONv-hcK32Y]BRICO: INSTALACION INDICADOR MARCHA EN VELOCIMETRO EN YAMAHA FZ6 S2.[/ame]
Now, I've typed the words on the vid into google's translator, it's a bit rough as most is litoral except for a few where I worked out that google put the translated words in the wrong order. So there may be a few with the words jumbled...
00:06 [this is a time stamp for you to refer back to if you loose track]
DIY
INSTALLATION OF A
GEAR INDICATOR
IN THE PANEL
YAMAHA FZ6 S2
carlosn888
00:12
Previous installation
00:24
Remove 3 screws top
00:38
remove 3 screws from the speedometer box
01:00
extract connector
01:12
We released the speedometer
01:23
we take gear indicator
01:31
started to remove the speedometer (on a black screen)
01:42
remove all screws
01:50
top out
02:04
we take the circuit
02:18
REMOVE THE NEEDLE HOLDING IT (next black screen)
by the black circle and throw up strong (i think it means pull up hard)
02:35
the 2 screws out
02:43
now work with numerical cap (the tacho dial)
02:57
MAKE A COPY OF THE SAME SIZE AS THE PROGRESS INDICATOR (refers to the gear indicator)(next black screen)
paper tape (use masking tape)
03:14
WHERE WE DO MARK HOLE FOR INDICATOR (next black screen)
03:30
We stress BLADE WITH PAPER TEMPLATE (next black screen)
AND NOW WE CAN REMOVE
03:47
PUT TAPE BLADE MARKED AS
03:59
WITH A COTTON SWAB AND NAIL POLISH REMOVING PAINT WE
04:10
USE TAPE
RIGHT TO THE
VERTICES (edge maybe?)
04:27
WE HAVE ALREADY AHEAD
04:38
THE SAME OPERATION FOR
BACK
04:49
TOP AFFIX (NEXT BLACK SCREEN)
NUMERICAL, SPEEDOMETER
WELL WHERE AND FOUND
WILL MAKE THE HOLLOW
MARKING
05:12
WE USE A DREMEL SURPLUS TO CUT PLASTIC
05:36
WE HAVE THE HOLLOW
05:47
DESOLDERING THE 10 INDICATOR PINS
05:59
LENGTHENED WITH WIRE 20CM.
06:20
WE CLEAR TAPE DOUBLE SIDED ON THE SCREEN
06:39
WE STUCK IN PLACE
07:06
WE PLACE NUMBERING IN THE SPEEDOMETER
07:26
SCREWED DOWN
07:36
PUT THE NEEDLE
07:47
PRINTED CIRCUIT STICK SIDED TAPE (tape the pcb down)
08:42
WE PUT ALL SCREWS
09:15
INTRODUCE CONNECTOR TO SPEEDOMETER THE MOTORCYCLE
09:28
BECOME PUT THE SCREWS IN SUPPORT
09:38
AND FINALLY THE TOP
09:48
WORK COMPLETED
WATCH VIDEO OF OPERATION
IN YOUTUBE
SEARCH IN: CARLOSN888
So to answer Blanchy's question on what chemical to use on the dash facia, they say to use nail polish remover, which is just Acetone.
I would try a bit on the back and make sure the acetone is not too strong and is only going to take the paint off and not melt or deform the plastic dash panel first.
So here is the vid:
DIY
INSTALLATION OF A
GEAR INDICATOR
IN THE PANEL
YAMAHA FZ6 S2
carlosn888
00:12
00:24
Remove 3 screws top
00:38
01:00
extract connector
01:12
01:23
01:31
01:42
remove all screws
01:50
top out
02:04
we take the circuit
02:18
02:35
the 2 screws out
02:43
02:57
03:14
03:30
03:47
03:59
04:10
USE TAPE
RIGHT TO THE
04:27
04:38
BACK
04:49
MARKING
05:12
05:36
WE HAVE THE HOLLOW
05:47
05:59
06:20
06:39
WE STUCK IN PLACE
07:06
07:26
SCREWED DOWN
07:36
PUT THE NEEDLE
07:47
08:42
WE PUT ALL SCREWS
09:15
09:28
09:38
AND FINALLY THE TOP
09:48
WORK COMPLETED
IN YOUTUBE
