FZ1inTX
Adminstrator
I've been following this post for a while and I am really intersted in ivans ecu flash, I have pcv blocked ais, airbox mod, no flies, bmc filter, slip on cat gut, I want to get the flash but that has to wait until winter because my bike is my only ride to work currently. My question to anyone out there with similar mods running jondaddy82 map (or any stage 3 map) and is really happy with results what is your min tps setting? If adjusting mine will make it better I'm all for it. Currently seems to be lean at lower rpms and still pops on heavy decel. My tps is currently .754
I would use the PCV and shoot for the 0.640 now and try it. It certainly will not hurt. I couldn't believe such a small adjustment could make that much difference.
I have to talk to Ivan or, maybe he'll see this first.... I nailed the .640 setting at 174 degrees, but after the bike is at running temp (Thanks Ivan for the new fan settings!!!) this shows 0.635 so my question is, is this acceptable or should I move to 0.645 so it lands at 0.640 while at running temp?
